did anyone see the episode of musclecar where he showed how to rebuild a 350 turbo? rebuilding the front pump he installed a clutch in it to make it stronger, what clutch out of the trans was it?
Hi
From what you have described briefly they are using a low reverse clutch with all the material scraped off on both sides. Then they cut one side open so that you can install it under the piston in the front pump cover to shim the piston out. That would intern reduce you clutch clearance to between .040 and .060
for a faster apply.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
