musclecar episode - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2007, 04:42 AM
runn141's Avatar
musclecar episode
did anyone see the episode of musclecar where he showed how to rebuild a 350 turbo? rebuilding the front pump he installed a clutch in it to make it stronger, what clutch out of the trans was it?
Old 12-02-2007, 05:44 AM
Stanley H's Avatar
musclecar episode
Hi
From what you have described briefly they are using a low reverse clutch with all the material scraped off on both sides. Then they cut one side open so that you can install it under the piston in the front pump cover to shim the piston out. That would intern reduce you clutch clearance to between .040 and .060
for a faster apply.
A re-run of Overhaulin' or new episode tonight? Hippie Hotrodders' Lounge 18 12-21-2006 08:09 PM
Picture update on my blowby episode. Bad Rat 414 Engine 15 10-01-2005 01:04 PM
Monster Garage...The Chevy episode. A32flathead Hotrodders' Lounge 54 03-21-2004 06:49 PM
American Chopper, the Christmas bike episode hotwheels55 Hotrodders' Lounge 23 12-29-2003 03:22 PM
lowering a musclecar Adrenaline_Fiend Suspension - Brakes - Steering 5 07-30-2003 02:28 AM
