must I use proportioning valve on boosted drum brakes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2012, 02:22 PM
fat fenders 4 ever
I want to use boosted dual MC on all drum set-up. Must I still use proportiong valve and pressure control valves?
Old 06-19-2012, 02:36 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If you wish to balance the brake effort from front to rear..Yes..
Sam
Old 06-19-2012, 02:40 PM
fat fenders 4 ever
Thanks Sam.
I just don't know if the prop valve from disc/drum will work. Or, must I get an adjustable valve? Thanks for guidance.
Old 06-19-2012, 03:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Mopar6
Thanks Sam.
You don't need a proportioning valve but it may help stability under hard braking to use a hold-off valve to the fronts.
rear end disks brakes that bolt up in place of drum brakes that has a 383 465hp engin calon Introduce Yourself 2 01-23-2011 06:52 PM
2lb. residual valve with drum brakes runn141 Suspension - Brakes - Steering 3 09-06-2010 06:56 AM
Drum/Disc Brake Proportioning Valve Help leejoy Suspension - Brakes - Steering 2 03-22-2010 09:59 AM
Adjustable proportioning valve for drum system? MM in NM Suspension - Brakes - Steering 1 11-10-2005 10:04 PM
