-   -   Must II brake lines (http://www.hotrodders.com/forum/must-ii-brake-lines-134061.html)
4EyedTurd 02-25-2008 02:41 PM
Must II brake lines
I put on some 2" drop spindles and with the granada brakes it looks like the brake hose coming from the caliper is going to hit the stock upper control arm. Does anyone run a 90* fitting on their brake lines or have any other suggestions??
327NUT 02-25-2008 04:54 PM
Can't tell without looking but can you use a 90 deg. banjo fitting off of it?
Cape Cod Bob 02-25-2008 07:32 PM
u mite be able to swap left for right. bench bleed first. :confused:
bates_k 02-25-2008 09:12 PM
That would be your best bet, try http://pegasusautoracing.com/
for fittings and pre-assembled hoses
K
