Must II disc brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2007, 04:48 PM
Don Meyer's Avatar
Must II disc brakes
I am going to install a Must II crossmember in my 1948 GMC pick-up. I have new GM G-body metric calipers & rotors(10 1/2") & would like to use them on this project. Do I use the same bearings & seals on the Must II spindles as GM used on the G-body spindle or some thing else?........who is a good source to buy the caliper mounting brackets from?
Old 02-12-2007, 10:39 PM
no, you will need GM pattern rotors for the MII spindle
Disc Brakes TORI1 Transmission - Rearend 1 05-05-2006 09:12 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Does the 76 Lincoln Continental come with 9" and disc Brakes Tri5Nerd Transmission - Rearend 8 08-23-2005 11:22 AM
63 sub disc brakes or no disc brakes sub63 Suspension - Brakes - Steering 5 03-19-2005 11:31 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
