Must. II guys need some help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2008, 01:53 PM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
OK, "46 Chevy 1/2 T Panel Delivery, 350 SBC, Heidts cross member & Suspension, Flamming River manual rack. I've got a pretty good shimmie around 50/60 MPH and a little at low speed. I had 1 bad inner and 1 outer rod ends that were replaced and had the front end aligned at a good shop and watched it being done.
The final numbers are:
all numbers are degrees
Caster- L-1.4 R-1.5
Camber- L -1.1 R-1.4
Toe- 0.15 both
The wheels are Weld Wheel Pro Stars, 15" X 7"
We are thinking it might have something to do with the moveable weight thats inside the rims. And the front springs are Eaton 350lbs if it means anything.
Any ideas??
Thanks
Old 09-09-2008, 01:04 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
"Any ideas??"
Yep. Jack up the rear tires off the ground with the jack at the pumpkin and chock the front wheels. Get in and run the gears to 50/60 mph. Vibe not there, front tire balance. Vibe there, rear tire balance or driveshaft. Remove rear tires and run to speed. Vibe there....driveshaft. Vibe not there, rear tire balance.
Old 09-09-2008, 06:53 PM
AntnyL's Avatar
Originally Posted by techinspector1
"Any ideas??"
Great tip! And don't forget to use jackstands! I can visualize myself doing this, and the jack giving way, and........zoom! Right into the neighbor's pool!
Old 09-09-2008, 08:43 PM
Bluepen's Avatar
Just a firefighter
Wiki Edits: 2
Thanks for the info guys but I should have also put the shimmie is in the steering wheel not the seat, the driveshaft or rear tires will put the vibration in the seat. Right?
Lower control arm hits Granada rotor on stock Mus II suspension Darkman270 Suspension - Brakes - Steering 8 07-25-2006 01:26 PM
Later than Mustang II IFS moparist Suspension - Brakes - Steering 9 06-09-2006 07:09 PM
Help! I need advice..mustang II or granada swap? elwood741 Suspension - Brakes - Steering 6 05-21-2006 04:35 PM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
Mustang II BigChevMan Suspension - Brakes - Steering 5 07-04-2003 01:18 PM
