Must ll springs que - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2011, 04:28 PM
Must ll springs que
I want to put coil overs (front) in place of my regular springs, has anyone did this and what site to purchase these? I need to have the threaded stud at the top to tighten them down. Don't want to go expensive either, thanks
Old 12-23-2011, 04:36 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
just curious,
why the change?
Old 12-23-2011, 04:46 PM
Matt, I am going to have to cut them down maybe 2coils cause no way they will go in if I don't, and i'm thinking I might cut off to much, (but it has to be done). probably springs were to strong to begin with (fat man). Advice always appreciated, thanks, Dana
Old 12-23-2011, 04:48 PM
& matts38chev
are the springs still new?
did you get them from fatman or someone else?
Old 12-23-2011, 04:54 PM
Bought from fatman (must ll ifs) but I cut off 1/2 coil already so I am committed
Old 12-23-2011, 04:57 PM
& matts38chev
have you tried using a spring compressor tool?
I have the tool in the link, and it works well
we have lifted many coil spring toyota trucks
and without compressing the spring first, we would never get it back in some of the vehicles
Old 12-23-2011, 04:59 PM
& matts38chev
also on some of the trucks we have lifted
the directions say to drop one of the ball joints
then put the spring in and pry the ball joint back together
Old 12-23-2011, 05:29 PM
the diriections say to drop one of the ball joints
I have a spring compressor goes inside real easy to use but for some reason I think my spring has to be cut. I used the same one on my 39, 10 yrs ago worked fine. Just frustrated right now.
Old 12-23-2011, 05:44 PM
& matts38chev
dont cut any more
put it together, drive it for a month
it will settle some
does the vehicle have much weight on it now?
just chassis or is the motor in it?
or is the body on?
Old 12-23-2011, 06:29 PM
Springs
Motor is sitting in their. If I decide to go with coil overs, any suggestions? My panel van is being built so won't be driveable for quiete awhile.
Old 12-23-2011, 06:41 PM
& matts38chev
since it has some weight on it (to hold the chassis down)
i would disconnect one of the ball joints
put the spring in it
then use a jack to lift the arm up to put the ball joint back together
Old 12-24-2011, 07:43 AM
Wiki Edits: 27
factory springs
There were about a dozen different factory springs used on The Mustang II-pinto's. I was doing some mentoring to a kid that was road racing a mini stocker. I Had one of the Ford Chassis design engineers Print a copy of the spec sheet. Long since lost. It listed spring rate . free length, design in car height with various options, ride height, etc. Which springs used in different cars with different options. It was very usefull to get stiffer springs He needed with out raising the car.
Old 12-24-2011, 09:04 AM
& matts38chev
i would bet fatman can tell you what you have/why/if its correct
is there a number on the springs?
or help you with getting it in there
Old 12-26-2011, 03:30 PM
Springs
Finally got springs and gas shocks installed today, had a screwdriver laying under my upper arm so couldn't bring it down all the way to connect together-,DUMB. l might be loosing it- thanks for all the help, Dana
differnce in valve springs. will flat tappet springs work with a roller cam? hemiguy2009 Engine 1 01-31-2011 03:19 PM
81 c10 front coil springs swap for s-10 springs campracing Suspension - Brakes - Steering 3 10-05-2009 04:51 PM
Z28 springs gods_flame03 Engine 3 08-06-2007 10:57 PM
Hot springs AR mitmaks Off-Topic 5 02-01-2006 10:21 PM
Re arc springs 2" lower, or use 1" springs and blocks? Ripped Suspension - Brakes - Steering 4 10-23-2005 12:52 PM
