Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mustang 11 front end
Old 10-30-2008, 12:14 PM
P Fogel P Fogel is offline
Good advice from Bob
CapeCodBob told you some good things. I set mine up so that the lower control arms are parallel to the ground or close to it. The greater the spring rate, the more the angles change. You can buy spring spacers and long shock bumpers from Speedway Motors and correct some of the ride height. How is the jounce and bound?
