Mustang 11 front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2008, 09:47 PM
I just installed a new Southern Rods Mustang 11 front-end in a 1941 Chevy. I have 700 ibs springs and adjustible coil overs. The problem that I am having is the upper and lower A arms are pointing up and about 2-3 inches from being level. I installed 2" drop spindles but now the car sits too low. Any suggetion on why the A arms are pointing up and not level?
Old 10-27-2008, 03:05 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Put up some pics and someone will help.
Old 10-27-2008, 08:45 PM
Cape Cod Bob's Avatar
Me thinks 700lbs. is a little weak for a 41 Chevy. How did u arrive at that # ?
The bottom of the lower a-arm should be even with the bottom of the xmember. Dropped spindles will have no affect on this.
How much does the car weigh? Divide by 4. That should be the spring lbs.
Old 10-29-2008, 07:53 PM
powerrodsmike's Avatar
Wiki Edits: 161
Is your motor and sheetmetal all installed?
Later, mikey
BE different....ACT normal.
Old 10-30-2008, 12:14 PM
Good advice from Bob
CapeCodBob told you some good things. I set mine up so that the lower control arms are parallel to the ground or close to it. The greater the spring rate, the more the angles change. You can buy spring spacers and long shock bumpers from Speedway Motors and correct some of the ride height. How is the jounce and bound?
Pat
Front End Locks Up ? litoagain Suspension - Brakes - Steering 3 10-24-2008 09:20 AM
54 chevy with mustang2 front end 8283hockey Suspension - Brakes - Steering 2 07-31-2006 08:37 PM
Mustang II front end QUESTION??? testlightST Introduce Yourself 2 12-30-2004 10:31 AM
38 chevy, subframe it or put a mustang 2 front end on it? violent j Suspension - Brakes - Steering 4 07-11-2004 10:15 PM
mustang 2 front end ridener Body - Exterior 1 10-30-2001 08:15 AM
