mustang 11 front end in a early nova
What are the pro's and con's of installing a mustang 2 front end in a nova ?
Any help greatly needed, Thanks in advance. |
I would imagine that the structure of the Nova would be strong enough to support the M11 front end....However, if you plan on removing the spring wells for more engine room, I would be looking into strengthening it.
Ontario Rodders |
i was offered the front end for a 100.00 dollars , i have too remove it from a donor car !
OK, heres the thing...Thought you were talking about an aftermarket M11 crossmember......Using an original out of a car will be a ton of work.
Ontario Rodders |
I titally agree with Poncho, and by the time you get done it you will probably end up having to by and make a crossmember for the Nova anyway,
In the other hand provided they are in good shape $100 for upper and lower control arms, spindles, brake strut arms and rack (even as a core) is not a bad price and a lot cheaper than buying aftermarket. |
Thanks for the replys,way too much work ! not worth my time
I think if it was out of the car already it might be worth it. |
| early comet engine swap (or early mustang) | REALGONEKATT | Engine | 14 | 11-04-2007 06:15 PM |
| early nova hubs needed | Prof. T. Soggmeyer | Suspension - Brakes - Steering | 10 | 12-11-2006 12:07 PM |
| wayne dues front clip for early nova | ken scott | Suspension - Brakes - Steering | 3 | 01-12-2006 08:57 PM |
| Early Nova V-8 Oil Pan Front or Rear Sump ? | yekoms | Engine | 3 | 11-25-2005 07:04 AM |
| early nova disk brake conversion | hotrod66_57 | Suspension - Brakes - Steering | 2 | 04-29-2005 01:55 AM |
