mustang 2 calibers walk-thru? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2008, 07:17 PM
Hello all.
I am replacing the front calipers (and switching to rotors to a Chevy bolt pattern) on my car that has been changed to a mustang 2. I could really use a walk-thru of setting up the new calibers. I have never would with a 2 piece caliber before. I have always owned Chevys in the past.
Anyone got a link to a walk-thru or Adivce?
Shawn
Santee, SC
Old 01-20-2008, 05:41 AM
streetrodderbn's Avatar
Certifiable Streetrodder
Okay, first I need some more information, you said you are replacing the rotors with chevy bolt pattern, but are they mustII style rotors? then you said you are replacing the calipers, are they must II as well,or some other ford caliper? Are you using the factory Ford must II caliper brackets?
Old 01-20-2008, 06:19 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Do you mean a two piece caliper? or a two piston caliper?
Old 01-20-2008, 09:25 AM
The new rotors are mustII style but with a chevy 5 lug (Speedway)
I am using the original bracket mustII brackets with some remaned calipers.
New pads.
Old 01-20-2008, 03:07 PM
aka Duke of URL
Very simple. Refer to the below thumbnail.
Remove the set screw (retainer) and drive the key out with a punch. The caliper will fall out.
Slide the top of the caliper housing into the upper support bracket, take the spring and lay it over the key and drive the key and spring (together) into lower mount braket with punch. Install retaining screw.
Name:	Disc Brake Key.jpg
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
1999 Mustang Project BIGK Hotrodding Basics 5 11-16-2007 05:12 PM
Will a 390 fit or work in a 73 Mustang..... onebadmerc Engine 4 12-08-2005 09:57 AM
04 mustang rust oldred Body - Exterior 3 07-19-2005 07:15 AM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
