-   -   mustang 2 front end (http://www.hotrodders.com/forum/mustang-2-front-end-26.html)
ridener 10-28-2001 09:18 AM
mustang 2 front end
I bulding a 1928 ford! I put a mustang 2 on
the front.mt fender braces dont fit any ideas
also where my head lights brace does not bolt up to the fenders at the right place any ideas.what did i do wrong? <img src="confused.gif" border="0">
[ December 06, 2001: Message edited by: ridener ]</p>
falconsprint63 10-30-2001 08:15 AM
OK, so there are a lot of what if's to my reply and I am basing my response on my experience with a 33 ford.
1) did you use an aftermarket kit or a real mustang II unit. If it is a kit, call the manufacturer and ask them how to remedy the problem, the probably planned for it.
I installed an actual Mustang unit in my truck and ran into two problems. One, the upper A arms hit the fender. Two solution: cut a hole in the fender and build a recess for them or change to a tubular a-arm setup (I cut the holes b/c at the time I was in high school and didn't have the funds).
As for the fender braces themselves, you probably won't like this answer, but I moved them. I acually changed from the 32-34 truck braces to car brace and relocated it slightly. It may not be the pretties fix, but it works.
I stress again that these were problems on a 33, but I imagane the problem isn't too different. Good luck
matt
