mustang 2 front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2001, 10:18 AM
New Member
Unhappy mustang 2 front end
I bulding a 1928 ford! I put a mustang 2 on
the front.mt fender braces dont fit any ideas
also where my head lights brace does not bolt up to the fenders at the right place any ideas.what did i do wrong? <img src="confused.gif" border="0">
[ December 06, 2001: Message edited by: ridener ]</p>
Old 10-30-2001, 09:15 AM
Post
OK, so there are a lot of what if's to my reply and I am basing my response on my experience with a 33 ford.
1) did you use an aftermarket kit or a real mustang II unit. If it is a kit, call the manufacturer and ask them how to remedy the problem, the probably planned for it.
I installed an actual Mustang unit in my truck and ran into two problems. One, the upper A arms hit the fender. Two solution: cut a hole in the fender and build a recess for them or change to a tubular a-arm setup (I cut the holes b/c at the time I was in high school and didn't have the funds).
As for the fender braces themselves, you probably won't like this answer, but I moved them. I acually changed from the 32-34 truck braces to car brace and relocated it slightly. It may not be the pretties fix, but it works.
I stress again that these were problems on a 33, but I imagane the problem isn't too different. Good luck
matt
front end too low mopar 36 Suspension - Brakes - Steering 21 11-19-2008 05:44 AM
Mustang II front end stut rods, older or newer style better? Maxine Suspension - Brakes - Steering 3 09-13-2006 03:15 PM
mustang front clip Stangman196700 Body - Exterior 2 09-24-2004 08:43 PM
front end problems tonylsg Suspension - Brakes - Steering 13 04-15-2003 07:47 PM
Merc front end swap? senor_limpio Body - Exterior 5 11-11-2002 09:07 AM
