mustang 2 front end install - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2011, 05:46 PM
Question on the installation. we have the front end installed with the air bags it is the spindle too a arms I am concerned about. when we put them on the ball joints and tighten the ball joint nut it goes way past the hole for the couterkey does anyone know if there is some step I am missing or possible the wrong ball joint or spindle?
Old 04-22-2011, 07:18 AM
Irelands child's Avatar
Sorry you don't have an answer, but your post didn't make any sense to me and possibly to others. Pictures also help
Irelands child
Old 04-22-2011, 07:31 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
my first question is what brand are the parts?
did they all come together as a kit?
or are you mixing and matching parts brands/suppliers?
if they all came together from the same place, i would be on the phone to the supplier.
if you bought all the parts from different places, you could maybe use a washer (i would not recommend this)
but i bet you could get a taller castle nut.(i would recommend this one though)
Old 04-23-2011, 08:43 AM
ill read between the lines on this: if it is a heidts ,there is a thick washer that
takes up that space. hope this helps.
Old 04-23-2011, 09:37 AM
& matts38chev
is a washer on ball-joints common?
i may have mislead you on my recommendation on not putting one on there.
Old 04-23-2011, 09:47 AM
the washer im talking about goes on the lower part of the spindle before the nut. ( we may be talking about something diff.)
Old 04-25-2011, 02:00 PM
slow4dr's Avatar
^^^This
The thick washer goes between the castle nut and the spindle for any MII spindle using the Chrylser ball joints.
-J
Front air bag install OneMoreTime Suspension - Brakes - Steering 5 02-14-2011 04:48 PM
stock mustang II install 111goose Suspension - Brakes - Steering 4 07-26-2010 07:17 PM
35 chevy mustang II install dzo20 Suspension - Brakes - Steering 11 01-09-2008 06:29 AM
Mustang II Front end install hotrodnewby Suspension - Brakes - Steering 3 12-13-2006 06:36 PM
Mustang II crossmember install jhanjr@swbell.net Suspension - Brakes - Steering 2 06-20-2002 07:09 AM
