mustang 2 ifs install - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2012, 10:30 PM
Hey guys Im installing a heidts mustang 2 in my 49 ford truck. I centered it in the fender and put the A arms on, spindle, rotor, and tire. Looks right on center but I concerned when the caster is put in the wheel would move to the rear which would make it not centered any more. It calls for 1 degree of caster. I could move the wheel ahead a little to make up for the caster. how much I dont know, or am I going about this the wrong way. I need help on this so I dont weld the crossmember in wrong. Thank you
Old 03-06-2012, 10:14 AM
IMO, a couple of degrees of caster won't matter much....but you are correct in your thinking. You could cheat slightly forward from eyeball perfect. To me the most important thing is to be at ride ht. when you eyeball. My 55 Chev PU needed 1 1/2 inches at ride ht. to look right. I don't think the eye will see 1/8 to 1/4 inch in caster degree difference.
Old 03-06-2012, 11:56 AM
Thank you much for your help. I was not sure how much 1 degree of caster was. I do have it at ride height.
mustang 2 front end install ttkbf1012 Suspension - Brakes - Steering 6 04-25-2011 01:00 PM
stock mustang II install 111goose Suspension - Brakes - Steering 4 07-26-2010 06:17 PM
35 chevy mustang II install dzo20 Suspension - Brakes - Steering 11 01-09-2008 05:29 AM
Mustang II Front end install hotrodnewby Suspension - Brakes - Steering 3 12-13-2006 05:36 PM
Mustang II crossmember install jhanjr@swbell.net Suspension - Brakes - Steering 2 06-20-2002 06:09 AM
