mustang 2 suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2008, 09:19 PM
i am looking for info on mustang 2 suspension setups...i have a 47 chevy fleetline and am going to be needing to put in new suspension and this seems to be the best thing to do and wondering if anyone has done it and has any pics?
also where can i find a cheaper priced one from? i dont have a lot of money to spend on this....
it will be getting air bagged..
any info and pics would be great
thanx
nick kendall
Old 09-06-2008, 10:11 AM
Wiki Edits: 49
I wouldn't skimp on a Mustang II setup. At least not on the crossmember and top hat kit. Heidts has always been my choice since their geometry exactly matches Fords design. That can't be said for some of the other Mustang II IFS manufacturers. The control arms, spindles, and struts can all be found at swap meets if you need to save money.
Go to the link below my name and click on the past projects (41 Chevy and 53 Pickup) on the left side of the page. Each one of them had a Heidts Mustang II IFS installed with pictures and narrative. The 41 Chevy coupe has the same frame as your 47 but the detail and explanations given with the 53 Pickup are in much more detail and should explain things a lot better.
Good luck.
Old 12-23-2008, 01:04 AM
Hey I checked out your page, the 41 looks great! Im doing a 48 and have a question: Did you use 2'' drop spindles or just standard ones in your car??? Thanks.
Old 12-23-2008, 01:38 AM
Chassis Engineering has a bolt-on crossmember and top hats if you don't know or have someone to do welding (you can also adjust the ride height). Total Cost Involved has a combination bolt-on/weld-on kit. I'm building a '46 Coupe but am keeping the original suspension for now. Not enough money for a MII...
Old 12-23-2008, 08:55 AM
Wiki Edits: 49
Standard Mustang II spindles.
Old 12-23-2008, 11:19 AM
rachet ralph's Avatar
heres a company that may help you with your front end build, they have about anything to fab up a suspension and frames, go check them out!
www.welderseries.com
Old 12-23-2008, 02:26 PM
Ok thanks, what is better for strength? Tubular or stamped control arms? I want the Heidts and for my 48 I was just going to use the econo front end. Any suggestions?
Old 12-23-2008, 03:46 PM
Will I ever get it done?
Last journal entry: Hood
You can see my in-progress installation of a TCI MII front end on my 41.
66 mustang coil-over front suspension ? 6T6fstbk Suspension - Brakes - Steering 2 04-06-2008 09:09 PM
Mustang II front suspension worth salvaging? Arrowhead Suspension - Brakes - Steering 7 02-16-2007 07:03 PM
Mustang II suspension guru's Seijuro Suspension - Brakes - Steering 6 11-11-2005 09:51 PM
Mustang ll Suspension Measurements Wayne Rogers Suspension - Brakes - Steering 7 06-08-2004 11:33 AM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 01:43 PM
