Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mustang 2 suspension problem
Old 03-15-2013, 04:46 PM
46streetrod 46streetrod is offline
Yes caster plays a major role in ft. suspensions. Are you using a GM pump with the MII rack? If so you will need a different flow control valve in the reaar of your pump.Remove your pressure line then remove the nut that the line came out of. That is the flow valve.The difference is the port size of the two valves.This restricts the flow to the rack.Too much flow will cause the MII to feel to loose or out of control.There is also a shim kit for the relief spring but sets your pressure. Most of the time the valve will cure your problem Cost is $27.00
