Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mustang 202/6 with 3 speed to 302 V8
Old 08-16-2007, 09:07 PM
matt167 matt167 is online now
Wiki Edits: 31
well the 200 engine has a diffrent bellhousing than the 302, you need the bellhousing from a 289 or 302 car. I would not worry about the trans, the 4 lug 7 1/4" rear end is what I would be afraid of, there weak for a stout 6, let alone an 8. pesonally I'd keep the 6, you can make it as potent as a mild 302. theres a new alloy head out, and plenty of parts for them, not to mention you won't have to update the suspension or install all 5 lug parts, or the V8 steering box ( most people ignore this weak link, the 6cyl version is lighter duty ), you might have to install a 8" rear if you plan on running it real hard. I'm stuck on the 6cyl's myself. I have a turbocharged '67 200 that I built myself, it's all custom ( 2.3 Ford 4cyl pistions, custom cam, diffrent year head, dual roller timing chain from australlia, roller rockers from australlia, Ford 302 intake valve springs for intake and exhaust, 302 2 peice valve spring retainers with stock 200 centers, Turbo's from a Buick 3.8 ) and I have around $3,500 in the motor, it's in a '67 Falcon 4dr. oh yeah, a 202, is a .030 over 200, actully a 202.3.
