Mustang 351 mustang install - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2010, 04:02 PM
HEllo, i am in the process of buying a 351 carbureted engine and an auto matched up to it. i was wondering what would i have todo o get it to sit on my engine mounts in my 1980 mustang???. do i have to fabricate mounts and crossmember? i can get ahold of 302 frame parts. what do i need if anyone has done this swap before. and what rearend would hold up to this engine. i know my 7.25 wont handle but one snap of the throttle and itll be junk.
Old 04-28-2010, 04:13 PM
ericnova72's Avatar
More for Less Racer
The 351Windsor and 351Cleveland will both fit in this car, which do you have??.
Both will fit on stock 79-93 Fox chassis 302 mounts as long as this car came with a 4cyl or V8 originally, if it came with a straight six you will have to mod the crossmember, I'm not sure about differences if it had a V6.
You will need either a Fox-body specific 351W or 351C swap pan and oil pick-up to fit the chassis depending on which engine you have. Headers will also have to match either engine and the Fox chassis.
The rear to get that is plenty strong enough and a bolt-in is the 8.8" Ford out of a similar bodied Mustang GT or V8 LX.
Old 04-28-2010, 04:39 PM
Wiki Edits: 31
easier just to buy the correct crossmember
Old 04-28-2010, 05:37 PM
no prob about the crossmember i can get one from a junkyard. but the engine mounts. the plate where the engine mount bolts to on my car has a few holes already drilled in it. what is the difference in the 351 blocks?
Old 04-28-2010, 05:41 PM
it is a 351 winsor
Old 04-28-2010, 05:45 PM
will an 8.8 out of a meverick work in my car?
Old 04-28-2010, 05:46 PM
ericnova72's Avatar
More for Less Racer
Originally Posted by 74chevyflat
it is a 351 winsor
It will bolt in on the 302 mounts, you just need 351W specific oil pan for Fox chassis and 351W headers for Fox chassis.
What engine was originally in this car??
Old 04-28-2010, 05:50 PM
ericnova72's Avatar
More for Less Racer
Maverick is not 8.8" it is only 8", totally different year and weaker anyway than the 8.8". Maverick is also leaf spring and '80 Mustang is factory 4-link, can't be swapped.
8.8" is '85-up Mustang, started being installed when the first fuel injected 302's were put into production.
Old 04-28-2010, 06:04 PM
umm i can get my hands on a rear end out of a 1984 lx convertible??? would that be any good>
Old 04-28-2010, 06:17 PM
i can get a 1984 lx convertible. would it be any good?
a guy is selling the rear-end tranny driveshaft, and tranny . for 250 because its taking up space at his house.
Old 04-28-2010, 10:23 PM
Wiki Edits: 27
oil pan
Check out an oil pan out of a 351 van might work for you , oil pan pick up tube and long stud end bolt, some racers slot the front crossmember to move it foreward and slot the motor mount bolt holes to move the engine rearward to get more weigth to the rear and better traction.
Old 04-28-2010, 10:28 PM
Wiki Edits: 27
fox floors
most V8 fox floors start cracking under the driver's seat. Police mustangs had additional bracing thats no longer on the parts rack. you will need to get the sub-frame stiffener kit and cowl to shock tower bracing.
Old 04-28-2010, 11:21 PM
ericnova72's Avatar
More for Less Racer
84 still has the same weak 7.5" rear you have now. Has to be '85-up V8 car to have the good 8.8" rear. GT or LX with V8, 1985 and newer.
The correct oil pan is specific to a 351W in a Fox chassis, nothing else is going to work without cutting the crossmember or the pan somewhere.
Old 04-29-2010, 07:30 AM
Wiki Edits: 27
bigger brakes next ?
Upping the horsepower will make bigger brakes necessary. the 5 bolt lug brakes came out of the parts bin. later spindles, linclon rotors and calipers, towncar or mark rear brakes. ranger 5 lug rear axle shafts. the mustang guys have articles and lists of what parts you can find for cheap to make it all work.
parts for 351 windsor Doug Renton Engine 5 09-13-2009 02:18 PM
351 Yates heads C-3 1971-73 mustang fordpwr4u General Rodding Tech 6 12-09-2005 07:52 PM
MUSTANG 289 into 351? or Bigger? exiled1 Engine 17 11-20-2005 12:12 PM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
