Mustang C4 Tranny Compatibility - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2011, 08:52 AM
USMCDCC's Avatar
Ok, I have a C4 Tranny that was attached to my 67 289 Engine. I am considering using this tranny in a different project... the new engine is a 66 Ford Straight 6 set up.
Will everything bolt up correctly? Are all bolt patterns the same? If not, what do i need to do in order to get this tranny / engine combo matched up (if at all possible).
Thanks...
Old 05-09-2011, 10:35 AM
Irelands child's Avatar
The C4 has a separate bell housing that may need to be changed. There are at least 6 different bell housings, but the transmission is the same until you get to the input spline - then the torque converter has to match. Depending on the year, that spline went from 24/24 to 26/26. The cut off year is 1970 but in '71 Ford went to a 26/24.
Then those bell housings - that also meant a different diameter flex plate and ring gear tooth count number plus the right converter. Not insurmountable once the transmission is out - but a crap shoot after 40 plus years and folks fixing plus mixing and matching.
Oh yeah, then there is pan fill (early) and case fill (later) versions, but that should not make any difference
Do you have a headache yet??
Parts are easily and fairly reasonably available.
Dave W
Irelands child
Old 05-09-2011, 10:44 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
For the 200CI 6cyl. You just need to use the 6 cylinder bell housing, converter, & flex plate, & your C4 will bolt right up.
Rich
Old 05-09-2011, 01:05 PM
USMCDCC's Avatar
Ok, so... next question...
What should I expect to pay for a used C4?
Also, as for the bell housing, converter and flex plate... what should i expect those to run me?
Old 05-09-2011, 03:53 PM
Hi
If you don't have the block plate you'll need that also.
They have it at the link, It's a used part $50
Don't you have any of these parts? wasn't the converter & flex plate with the trans? why are you asking the price of a C4 you said you have one, is it burnt-up? These transmissions are simple to rebuild. (you rebuild around $300)
You can buy a new flex plate at the auto parts store. I think it's 157 tooth $45.& up
The converter, you need to know the spline count of the trans your using to get the correct converter?
Bell housing
http://motors.shop.ebay.com/__?_from...p_id=410759362
Block plate
http://cgi.ebay.com/ebaymotors/1965-...item2eb08fe8ca
Rich
Mustang Motor/Tranny mustangman46 Engine 6 08-26-2007 12:24 PM
HELP...my tranny is going nuts 67 MUSTANG exiled1 Transmission - Rearend 1 05-12-2006 06:10 AM
C-4 65 Mustang Tranny Rebuild 65Mustang289HIPO Transmission - Rearend 13 05-02-2006 12:47 PM
Auto -> Manual tranny swap in a '03 Mustang Italy's Finest Transmission - Rearend 1 07-31-2005 07:46 PM
Transplant 302 and AOD tranny into 80 mustang bildo95 Transmission - Rearend 1 08-26-2002 09:47 PM
