mustang clutches - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2003, 03:48 PM
Auto's Avatar
Post mustang clutches
I was wondering how hard it is to change a 68 mustang from automatic to a manual transmission and if you can put a newer 5.0 5 speed transmission in the 68.If it will fit
Old 05-20-2003, 04:28 PM
woodz428's Avatar
Troll Hunter
Arrow
Check out Mustangs Plus at www.mustangsplus.com
they offer a kit to do just that.
Old 05-20-2003, 09:29 PM
mustang66maniac's Avatar
Ford Freak
Post
Its damn easy. Youll need to find a donor car to get the clutch linkage and pedal from. Youll also need to find the correct flyweel. Then all you need is the crossmember. Everything else is pretty easy, just cut open the shifter hole, add a spacer to the fulcrum of the shift fork on the t-5 bellhousing and your all set for the 5 speed, everything will bolt right up. Check out this link for the swap.t-5 swap
