Mustang EFI in a 31 PU - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 06-17-2013, 09:05 AM
I have a 2007 Mustang V6 4.0 & trans (5R55S) in my 31PU. My knowledge of EFI leaves a lot to desire.(I'm 65 yrs old) I have the engine harness, PCM, underhood fuse/relay box, gas pedal from the original car. I bought an SCT handheld tuner with a program to turnoff the PATS. And I got the wiring schematic. HELP PLEASE!!! I don't know where to start. I have an ignition switch (S10), but can't figure where to wire it in. I have figured out which wire is what with the switch. My PCM has 3 plugs, I have 2 of them, eng and trans I hope. My underhood fuse box has 4 plugs, I have one. It seems to me that if I knew where to wire in the ignition switch, that hopefully it would fire. All my sensors are plugged in, but the AC pressure switch and the power steering pressure switch. Do I need more from a 2007 Mustang. I have contacted Painless and Ron Franis about a wiring harness. But they only do 5.0, 4.6, or even 2.3 engines. I appreciate any help or advise on how to get it running. I have the chassis in mockup and want to get it running before proceeding on. Thanks Guys
Recent Modern Electronic Engines posts with photos
Non efi sender in an efi tank RotorHead Engine 5 07-26-2011 06:53 PM
69 Mustang- 302,351w, roller block,efi? pyr0 Engine 15 07-24-2008 08:59 PM
Cam for 460 EFI? EFI - Does it matter? offroadin Engine 2 06-22-2004 06:49 AM
Edlebrock EFI vs. Holley EFI trick66 Engine 2 03-22-2003 03:43 AM
EFI 5.0 in an early mustang! 68stang_99 Engine 3 08-21-2002 11:58 AM
