Is this a Mustang front end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2013, 04:34 PM
I have just bought this 1949 F1 fitted with air ride and I am told a mustang front end. I want to rebush it etc but am having bother identifying the year etc. Anybody recognise it?
cheers
Name:	f1 front1.jpg
ID:	70268   Click image for larger version
Name:	f1 front2.jpg
ID:	70269   Click image for larger version
Name:	f1 front4.jpg
ID:	70270   Click image for larger version
Name:	f1 front6.jpg
Old 01-03-2013, 04:59 PM
Last journal entry: T'Bird projectr
Looks like an old Camaro or Chevelle, what with the rear steer and all. What bolt pattern is it?
Old 01-03-2013, 05:05 PM
Yep, 67-69 Camaro. 70 and up had front steer.
And those aren't stock brakes so you are going to have to do some research to come up with the pads.
Old 01-03-2013, 05:22 PM
delawarebill's Avatar
bks ??
the calipers look like gm metric's.. early '70's
Old 01-03-2013, 05:39 PM
You know what, they may be original, I was thinking, the 67-68 had a four piston caliper I am pretty certain but the 69 I believe was single piston so it could be a 69 subframe.
Old 01-03-2013, 08:26 PM
life is a temporary assignment
It's Not a Mustang..
Old 01-04-2013, 05:51 AM
Thanks Guys, that was quick. I am not sure of the stud pattern other than it is a five stud. It has what look like Vintique wheels with two patterns ie 10 holes. I will measure up at the weekend and see if I can work it out. I will do some more research on the 67-69 Camaro route to see what I can come up with. I sent the pics to Real Steel to see if they could help but no reply yet.
Now I need to find out what carb I have on the 305 so I can rebuild it, some old single barrel leaky thing, might be best to replace with a four barrel and a manifold, but I'll save that for another post.
Came with an English MOT but lots to do to pass our Isle of Man test, oh well spanners ahoy!
Thanks again
Old 01-04-2013, 06:04 PM
It could also be 68 to 74 Nova, functionally the same subframe as the 67 to 69 Camaro, and many of them came with disc brakes.
Old 01-06-2013, 04:38 PM
Nova or camaro rear steer with a brake kit on it. looks like metric calipers With air bags look to switch the front sway bar to a little bigger one. It helps a lot.
Old 01-07-2013, 06:13 AM
Thanks, I am going to replace all the bushes etc. so maybe a new sway bar too. I'll see what parts I can track down.
Cheers
Old 02-06-2013, 06:10 AM
fingers crossed and thanks
Just to update this I contacted Summit with the pics and they confirm it is a first generation Camaro 67/69 so thanks for the help guys. I really hope it is as I am expecting delivery tomorrow of full front end rebuild with bigger sway bar, manifold & carb etc. Time to get busy.
air, bush, clip, mustang
Mustang II Front End Parrot Hotrodding Basics 16 07-21-2012 08:30 AM
Mustang 2 front end 47GMCdreamrod Suspension - Brakes - Steering 3 12-29-2011 12:38 PM
Mustang 11 front end crazysamuri Suspension - Brakes - Steering 4 10-30-2008 01:14 PM
Mustang II Front End......How to RDavid Introduce Yourself 5 08-12-2004 08:14 AM
Mustang front end help ! Blackbob Body - Exterior 3 01-23-2003 07:14 PM
