mustang front springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2007, 12:59 PM
I am looking for a suspension for my 37 plymouth , my question is do the stock type mustang springs work better or worse than the coil over shock type do , and if so why?
Old 08-06-2007, 01:27 PM
Wiki Edits: 27
mustang II front spring
I was an engineer at ford and helped a guy set up his road racer. The factory made 11 different springs that fit the M II front end... I lost the spec sheets long ago ... the springs gave different ride heights and rates. ... your set up will depend on how much weight ends up on the front and how you want it ro ride and handle .... adjustable coils are the best and of course will cost you more
Old 08-07-2007, 10:31 AM
37 plymouth coupe's Avatar
Re: mustang II Springs
everything you want to know about MII coils can be found here
www.eatonsprings.com
read the "tech" questions first, and then send mike an email. You will get a personal answer. Solved my spring problem on my 37 coupe
Old 08-08-2007, 12:11 PM
stock mustang springs verses coilovers
I am looking for a front suspension for my 37 ply, and would like to know which rides and handles better stock type springs or coilovers
Old 08-08-2007, 02:28 PM
As a Moderator here ... I joined two of your threads together ... their were the SAME question just worded slightly different.
Deuce ... Moderator
Mustang II Front End Parrot Hotrodding Basics 16 07-21-2012 07:30 AM
Quarter Elliptic front springs on straight axle woodcanoe Suspension - Brakes - Steering 4 10-20-2006 01:00 AM
Sizing Front coil springs JNJo39 Suspension - Brakes - Steering 4 05-09-2006 03:57 AM
Front coil springs too long. hrussel Suspension - Brakes - Steering 7 07-05-2004 08:23 AM
mustang front clip swap 2wld4u Body - Exterior 5 11-02-2003 09:07 PM
