mustang frontend /37 pu
I'm trying to put a mustng frontend under a 37 pu frame . could anyone tell me where to measure from the front of the frame to get the axle in the right place, the stock crossmember is gone any pics would help, THANKS pete
Here are a couple of links that will help you.
This is a set of instructions in PDF from TCI that shows the C/L of the crossmember, measured from a bumper bracket hole. http://www.totalcostinvolved.com/ins...m?ManualID=319 This is a link to a PDF showing frame dimensions and axle C/L from Wescotts Auto. http://www.wescottsauto.com/pdf2/FR-6.pdf All of the MII front ends that I have done had the spindle C/L in the center of the crossmember. One word of caution though, many of the old cars had the sheetmetal not lining up with the axle C/L, so you may want to check your axle location with the front fenders mocked up in position. Nothing worse than getting a front end all welded in and having the wheels not centered in the wheelwell. Hope this helps, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
Just what I needed
Thanks the diagrams were just I needed Thank you very much
| Anybody have a Jim Weimer Mustang ll Frontend? | TT66' | Suspension - Brakes - Steering | 10 | 12-31-2007 04:19 AM |
| Mustang II frontend | Robbie Autrey | Suspension - Brakes - Steering | 7 | 01-18-2007 09:21 AM |
| mustang II frontend kit | rolandag2 | Suspension - Brakes - Steering | 2 | 11-05-2006 09:29 PM |
| Using 84 Mustang Frontend under 51 Ford Tudor | bigbrowndog | General Rodding Tech | 1 | 09-18-2006 08:36 AM |
| 39 Chevy Pu Tilt Frontend | TOMMYDALE | Introduce Yourself | 4 | 01-22-2006 08:55 PM |
