Mustang II (1974-78) front brake caliper - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2005, 08:36 AM
I'm having difficulty figuring out which adapter I need from the caliper to a flexible AN3 brake hose. The caliper is stock. I've no way to gauge.
Old 02-26-2005, 06:15 PM
If I remember correctly, the caliper uses a banjo fitting which uses copper compression washers for sealing. The bolt that screws into the caliper is straight thread. You would need to find a brass adapter that has straight male threads and a shoulder that would seal with a copper washer when screwed into the caliper and the other end would have to be made to accept the AN fitting, either male or female.
Good luck.
Trees
mustang II caliper install..what are these parts RodFather Suspension - Brakes - Steering 3 12-04-2004 11:16 AM
Mustang II Front Suspension Specs... yekoms Suspension - Brakes - Steering 2 11-21-2004 09:59 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
mustang II brake help jniolon Suspension - Brakes - Steering 1 07-20-2003 08:00 PM
Mustang ii Suspension 41fordcoupe Suspension - Brakes - Steering 14 06-11-2003 08:12 PM
