Originally Posted by jaxhome
I tried Jegs again to ask about the chart from Tie Rod Boots. The guy I spoke with said they're not worth using because the have next to no lip on the bottom like mustang II ball joint boots normally do. One good bump and they slip.
Made of HYPER-FLEX™ Performance Polyurethane.
(A) Seals tight at tapered shaft
(B) Sharp edge helps seal-in lubricant
(C) Inside radius of boot works with rod socket as a wiper
(D) Extra sealing lips
(E) Barrel shaped for a better fit
They are made from Polyurethane and will not flex like OEM.
When I tried to get certain sizes from SUMMIT, they had to special order them as they only stocked certain sizes.
