i will have to check my hortons catalog when i go home but they list either the upper or lower boots for $5 ea. cdn
I have run into similar situations in the past. Damaged a brand new boot trying to seat it on the ball joint, and they tell me I have to buy a whole new balljoint,
Now I have a place to look should it happen again. I should have said the ball joint was faulty because the boot wouldn't fit without ripping. At least I now have an alternative. Thanks for another good score. |
ball joint boot.
hi magnus,the number hortons has listed is for the upper boot and its looks like it might be a heidts #CA-029 . maybe heidts has lower boots as well?
website for Hortons
I've been going nuts trying to find boots for my mustang II front end. I bought a car where the front end parts were in a box and the car used all the boots for another car. What's the website for Horton's? I've never bought anything from them.
My damaged boot was on a mopar. upper ball joint. They are threaded into the aframe and then you get to fight ot get them on. I've shredded one getting it on and roughed up several. It would be good to have new ones when ever you abuse them with the fork. Especially when i've paid at least $40 for a ball joint in the past only to have to use the old boot from the bad joint...
hortons web addy
www.horton.on.ca is the web address. looks like its the upper ones the show because the upper boots on my TCI arms look the same
I see what you guys are saying now. You are using specialty control arms not OEM with the OEM ball joint. You will have to find the vendor (supplier) of the ball joint(s) and see if they will sell the boots separately in that case.
FORD'S ball joints (design) are not tough enough for aftermarket use or are the aftermarkets just cheaper causing the supply problems you have? The OEM ball joint boots were available from FORD at one time. C7AZ 3A105-B Upper Boot C7OZ 3A105-A Lower Boot They would have been able to be sourced aftermarket also. The MUST II used heavy FORD joints. I am glad I found this out as if I were to have (do) one, it would have to have OEM components on it to make service a lot easier. |
| How to properly mate a GM pump to a Mustang II rack | Centerline | Suspension - Brakes - Steering | 73 | 10-31-2009 11:59 AM |
| upper ball joint boots | yezek6 | Suspension - Brakes - Steering | 3 | 03-29-2005 04:25 PM |
| Mustang II bump steer, drifting | Chev283 | Suspension - Brakes - Steering | 2 | 06-19-2004 08:15 PM |
| Are Mustang II Crossmembers Safe? | Jon | Suspension - Brakes - Steering | 14 | 10-17-2003 12:43 PM |
| Another Mustang II Question | hiimed | Suspension - Brakes - Steering | 7 | 06-30-2003 09:48 AM |
