We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 06-04-2002, 12:21 PM
jniolon's Avatar
jniolon jniolon is offline
New Member
Post Mustang II brake conversions
Hi Guys,
I'm looking at brake conversion kits for the MII front end and I see lots with ford rotors and chevy rotors but all seem to use Chevy Calipers. Can someone tell me why??
I'd love to keep everything one make under the front end if for no other reason, there's less for my tired old mind to remember
tia
john
Old 06-05-2002, 12:47 AM
deuce_454's Avatar
deuce_454 deuce_454 is offline
Post
well i asume that you want bigger brakes since you are asking a conversion...
the kits konsists of two 11 inch rotors, drilled for chevy or ford boltpattern. and a set of chevy single piston calibres, the reason is price (the calibres for chevy are plain and simple cheaper). and then the brackets to mount the calibres and some assorted nuts bolts and bareings.
id say go with it and try to remember, of have your wife write it down,
Old 06-05-2002, 07:58 AM
joegaddy joegaddy is offline
Talking
i used a kit from Chassis Eng. on my street rod that uses Granada calipers, works great. Joe
Old 10-21-2003, 08:03 AM
50sCarStuff 50sCarStuff is offline
MII Brakes
I designed a bolt on bracket that uses newer Ford calipers and the granada 11" rotors.
I also designed a bolt on bracket for the ford 9" rearend for 10.5" rotors and Ford rear calipers.
This set uses the calipers form a T- Bird or full size ford car, the rear calipers have the emergency brake set up on the caliper.
Old 11-20-2003, 09:05 AM
Mustang II Brakes
If You don't want to down grade to GM brakes go to
www.sachserodshop.com.
They have a 11" Granada rotor and Ford caliper adapter
for the Mustang II spindle.
Old 11-20-2003, 09:53 AM
EBlack36's Avatar
EBlack36 EBlack36 is offline
Rebuilt Excitment
Re: MII Brakes
If you could post a picture of this bracket, it would be be greatly appreciated.
Old 11-20-2003, 12:13 PM
jhenry's Avatar
jhenry jhenry is offline
I would like to see more info on this as well. I really like the idea of using Ford parts on my Ford. I have something in mind already, but would really like to see what your setup looks like. I'm always looking for the simplest solution for the least $$.
Old 11-23-2003, 09:23 AM
Mustang II Brakes
I have some pictures
I don't know how to post them
50sCarStuff
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
