Hotrodders Bulletin Board > Tech Help> Suspension - Brakes - Steering
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 11-02-2001, 10:45 AM
Willy J Willy J is offline
New Member
Question Mustang II brakes
I installed mustang II brakes, not GM, and ordered the stainless brake line kit with adapter. I put the adapter into caliper and then screwed the stainless line into adapter. It was almost like the threads were slightly different. It took a lot of force to get the line to go all the way into the adapter that was screwed into the caliper. Did I just screw it up?
  #2
Old 11-02-2001, 02:27 PM
KULTULZ KULTULZ is offline
aka Duke of URL
Question
In other words, you put a set of flexible stainless steel brake hoses onto the FORD calipers (front) and they needed an adaptor to mate to the caliper?
If the thread pitch seemed different, it probably was. You won't know until you have bled the system and apply the brake. Do it on stands and not on the street. Hopefully the adaptor was brass and can be replaced cheaply. They may have given you the wrong adaptor or hose for that matter.
Good Luck with it and let us know how it turned out.
Old 11-05-2001, 02:36 PM
New Member
Post
Originally posted by Willy J:
<STRONG>I installed mustang II brakes, not GM, and ordered the stainless brake line kit with adapter. I put the adapter into caliper and then screwed the stainless line into adapter. It was almost like the threads were slightly different. It took a lot of force to get the line to go all the way into the adapter that was screwed into the caliper. Did I just screw it up?</STRONG>
Thanks, I'll go ahead and bleed them before I panic...
Old 11-05-2001, 02:39 PM
New Member
Post
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
