-   -   mustang II brakes, spindles and caliper stuff (http://www.hotrodders.com/forum/mustang-ii-brakes-spindles-caliper-stuff-11940.html)
jniolon 06-25-2002 01:02 PM
I'm using a Heidt's MII crossmember on my truck. I plan on using 11" granada rotors and want to find some ford rotors that will fit. All the kits I see show chevy rotors with shimmed pads.. surely there is a granada or fairmont or ltd caliper bracket that will work with the '77 MII spindles I have so I can keep my whole front end Ford !! I have found sliding pin calipers but can't find a caliper bracket that will work.. There was a kit available from A-1 racing products for this conversion, but I think they are out of business...
any one out there who knows what will work for me
TIA
john
joegaddy 06-25-2002 01:51 PM
The one I used is from Chassis Engineering @ 319 6432645, worked great
Dave E Shank 06-25-2002 05:21 PM
I put in an ECI kit but was not happy with rotors because it uses a special oil seal. I would reccommend Master Power Brakes www.MPBRAKES.com GOOD LUCK Dave E Shank davesr@trianglesalesusa.com
