mustang II brakes, spindles and caliper stuff - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2002, 01:02 PM
jniolon's Avatar
Post mustang II brakes, spindles and caliper stuff
I'm using a Heidt's MII crossmember on my truck. I plan on using 11" granada rotors and want to find some ford rotors that will fit. All the kits I see show chevy rotors with shimmed pads.. surely there is a granada or fairmont or ltd caliper bracket that will work with the '77 MII spindles I have so I can keep my whole front end Ford !! I have found sliding pin calipers but can't find a caliper bracket that will work.. There was a kit available from A-1 racing products for this conversion, but I think they are out of business...
any one out there who knows what will work for me
TIA
john
Old 06-25-2002, 01:51 PM
Talking
The one I used is from Chassis Engineering @ 319 6432645, worked great
Old 06-25-2002, 05:21 PM
Dave E Shank's Avatar
Post
I put in an ECI kit but was not happy with rotors because it uses a special oil seal. I would reccommend Master Power Brakes www.MPBRAKES.com GOOD LUCK Dave E Shank davesr@trianglesalesusa.com
« IFS | Brake booster »
