mustang II clip on nash truck ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2008, 10:37 AM
ok im new here and have a question i have a 1929 nash and i have a mustang II clip.Now the clip is to narrow for the frame and was wondering what would be best to do widen the clip belly ?narrow a section in the frame? will take pics if needed
Old 12-04-2008, 02:29 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
What width is your nash frame up front? There are small Nashes & bigger Nashes. I think a stock M2 front end can trim out to 26". Is your frame more?
Old 12-04-2008, 03:04 PM
forestrytodd's Avatar
Official Hotrod Forester
Don't forget that ir you widen the clip then you will have to widen the rack to keep from having bump steer or a toe in/out problem as the suspension cycles up and down.
Old 12-04-2008, 04:00 PM
Cape Cod Bob's Avatar
No, no. no. You can widen the clip about 4" if I remember and use Fairmont tie rod ends.
Old 12-04-2008, 08:25 PM
my nash truck 27+ in and the clip i believe is 26
Old 12-04-2008, 09:15 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
forestrytodd stated it correctly, if you widen the crossmember you WILL have to widen the steering rack the same amount (not a practical solution). If you just change the tie-rod length, the relationship between the tie-rod arc and the control arm arcs will be drastically different. Bump steer will be the result.
If the track width is close enough to what you are looking for with the Mustang II front end, narrow the frame at the crossmember area to fit the suspension. If the crossmember is only an inch or so narrower like you state, it will be no problem to fit it into the frame.
Old 12-04-2008, 10:43 PM
ok thank you thats what im gonna do is just narrow it a lil bit
Old 12-05-2008, 07:45 AM
F&J F&J is offline
I assume you will be using original front fenders?
If so, you need to put those on, and then watch for clearance problems at the top A arms of that front end. I would think it may hit the fenders.
Old 12-05-2008, 09:43 AM
yes the original fenders me and my dad were just talking about clearence issues last night to
Old 12-05-2008, 09:56 AM
F&J F&J is offline
Cool...
Are the cowl lights missing?? There was a set just on ebay a week ago; I don't think they sold. They have "peaks" on the top, just like Nash headlights do.
Hey, I just might ask for a picture of what the door latch looks like ... mine are missing on my 32 nash
Old 12-05-2008, 10:02 AM
let me know i just bought some off of ebay about a week ago but i think they might be wrong and they were exspensive lol
Old 12-05-2008, 11:38 AM
F&J F&J is offline
This is what I saw on ebay. They look correct for your car "IF" the outer peaked rim can be turned 90 degrees. I think the ones in that auction are put together wrong. Most cowl lights with a "shaft mount" have the shaft vertical like your car does, not horizontal like the ebay ones. That's why I think they are assembled wrong..
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
So which ebay lights did you buy?.... I have been watching Nash stuff and I don't think I saw any others..
Old 12-05-2008, 11:54 AM
lol as i actually start to look at them i think there correct
Old 12-05-2008, 12:49 PM
F&J F&J is offline
Looks correct to me..
classy looking, too.
The tail light is tough to find. It also has a peaked top, but there are several sizes of Nash cars, so the lights are different sizes.
Old 12-05-2008, 12:56 PM
yeah im having trouble finding that and head lights i thought mine were good untill i saw the botom of them
Mustang II power steering johnhawes Suspension - Brakes - Steering 3 09-18-2008 04:07 PM
Mustang II steering/S10 suspension raj4851 Suspension - Brakes - Steering 1 08-11-2008 05:25 PM
29 A Tudor- Mustang II alignment 471A Suspension - Brakes - Steering 1 06-13-2008 06:25 AM
Help! I need advice..mustang II or granada swap? elwood741 Suspension - Brakes - Steering 6 05-21-2006 04:35 PM
Mustang II suspension components DossWallace Suspension - Brakes - Steering 7 04-04-2003 12:11 PM
