Mustang II front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2013, 03:35 PM
Can anybody identify the manafacture of this front end?
ID:	73447   Click image for larger version
Old 04-23-2013, 06:52 AM
454 Rattler's Avatar
NEVER SATISFIED !!
I can't ID the front end but, it looks pretty nice. Do you have a problem with it ?
454 RATTLER
Old 04-23-2013, 07:03 AM
BigMo's Avatar
That is a nice set up.....I have the same type of front end, but with painted tubulars arms and QA1 coilovers.....not nearly as purty as that rite there now!!
Old 04-23-2013, 07:34 AM
302 Z28's Avatar
Resembles the Heidts front end on my 34.
Vince
Old 05-01-2013, 02:53 PM
Looks like a hybrid of sorts to me.... The upper coilover mounts look like a fabricated piece and the control arms resemble an early TCI..... But I have no idea
Old 05-02-2013, 05:06 PM
I am just as confused as you. But thanks for the input, if we get enough I might find out who made them. I think they work fine for home made, but I have not driven any other Street Rod that had Mustang II front.
Old 05-06-2013, 04:12 PM
Irelands child's Avatar
Sorry to be so late with a response.
It looks to me as well to be TCI 'A' arms along with a home built shock mount and adjusting mecanism. If it's solid and the car drives well, leave it be as it does look like a good fab job.
This is my TCI, circa 2001 and 2011 :
Irelands child
Old 05-06-2013, 05:49 PM
sedanbob's Avatar
Irelands Child, Your TCI looks a lot like the front end I got from Pete and Jakes - the upper eccentric adjuster looks just like mine (except your is polished and pretty). The OP's upper mount is more like the original MII. The control arms look exactly like yours though.
ID:	73804   Click image for larger version
Old 05-06-2013, 07:31 PM
Makes you want to believe that P&J sub their front ends out to TCI. I have to say it that the front end does work nicely once you get the correct rate springs installed and on all 4 corners of the car.
As far as shiny and pretty - the downside is how much time it takes to keep it that way.
Irelands child
Old 05-08-2013, 06:16 PM
Could it be a "cobble job"? With parts from various MFRs? Looks like a good set-up though.
I'm not too hip on slotting a load bearing member as far as that one has been slotted.
Should have added an attachment for the upper control arm, rather than cut a slot in the compression flange of the frame. Unless there is hidden reinforcement for the slots.
Old 05-08-2013, 08:21 PM
sedanbob's Avatar
One of the nice things about full-fendered - hides a lot. The polished does look really nice!
Is this a Mustang front end? Norm3 Suspension - Brakes - Steering 10 02-06-2013 05:10 AM
Mustang 2 front end 47GMCdreamrod Suspension - Brakes - Steering 3 12-29-2011 11:38 AM
Mustang 11 front end crazysamuri Suspension - Brakes - Steering 4 10-30-2008 12:14 PM
Mustang II Front End......How to RDavid Introduce Yourself 5 08-12-2004 07:14 AM
mustang 2 front end ridener Body - Exterior 1 10-30-2001 08:15 AM
