mustang II front ends - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2011, 05:23 PM
I understand the mustang II is really common in classic cars and trucks but has anyone built one from a stock mid 80's mustang and either modified or built the crossmember into a classic truck in particular a 49 ford?
Old 06-06-2011, 05:39 PM
ericnova72's Avatar
More for Less Racer
1979-up Mustang is not Mustang II(1974-78), it is Fox platform. which is Macpherson strut and requires a tall shock tower in the engine compartment to fit it. They are not even close to the same.
I know someone who put the Fox suspension under both a 1965 Mustang and 1964 Fairlane, but both were drag cars with tubbed rears and lots of engine set-back to clear it all(460 BBF in both). It was a ton more work than a Mustang II. I didn't particularly care for it, made for a rather ugly engine bay with those big shock towers.
Mustang II is so popular because it is simple and takes up the least amount of space.
Old 06-06-2011, 06:32 PM
thanks that is a tremendous help.
Old 06-06-2011, 11:09 PM
techinspector1's Avatar
Wiki Edits: 326
Yes, there are fellows who have fabricated up their own crossmember, but you may find it is overall cheaper and easier to purchase a crossmember manufactured by one of the suppliers of these pieces and then attach your own boneyard parts to it, that is if you can find any boneyard MII parts. I like the kits that keep the strut rod rather than using a made-up fosdick bottom control arm without the strut rod. Also, using a spacer on the top of the spindle will allow the upper control arm to be installed tilted up at the ball joint end, thus providing some camber gain on turns.
MII front ends 41fordpu Suspension - Brakes - Steering 1 03-25-2010 10:24 AM
mustang odds and ends Knight_Mare Interior 4 05-02-2009 05:58 AM
A front ends fordinator Suspension - Brakes - Steering 4 08-21-2007 02:41 AM
Mustang front ends........... poncho62 Suspension - Brakes - Steering 11 02-02-2007 10:35 PM
tilt front ends Bumble Bee Body - Exterior 1 05-15-2002 08:30 PM
