Thanks for the reply, but Ineed to give you some more information itr appears.
1.) How do I go about setting the front camber and caster with a protractor and tape? I also think I have a problem when I put in the new Mustang rack. Like a dum..dum, I just bolted everything up and decided to worry about it later, and ofcourse, everything is whacked. If you seen the wheels leaning outward from top to bottom and felt how the thing hardly turns to the right, you would know what I mean. So how do I go about getting it all back in reasonable shape, including the tie rods.
2.) The vette rear end is a 58 which is a 4.11 like the 57 chevies as per a vette expert that rebuilt it. It has drum brakes and it is in this car just because its width is a perfect fit. So I am thinking the stock type manual 1" bore mustang master should be a good fit. I also plumbed this with straight lines - no proportioning valve or in line pressure valves. It was plumbed this way when I first got it with a single resevoir fruit jar type master cylinder, Mustang front with 9" discs and it worked well.
Thanks in advance for the help guys. You are helping me keep my hair.
