Mustang II IFS on a 37 Plymouth - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2007, 01:56 PM
Hi
I'm new to your forum and this is my first build. I'm looking for nayone who has some familiarity with putting a Mustang II front suspension of a 37 Plymouth. The frame rails are quite different than on Fords and Chevys in that there is a large hump in the rails over the axle position. I can't envision how the crossmember and motor mounts would be positioned. I'll be installing a 97 Firebird LT1 motor and electronic transmission.
Appreciate any help. Thanks
Old 04-10-2007, 05:23 PM
302 Z28's Avatar
Are you talking about grafting an actual Mustang II front suspension to the 37 frame (very ugly IMO), or are you considering a Mustang II geometry IFS?
Vince
Old 04-11-2007, 11:00 AM
Looking to purchase a Mustang II IFS setup from one of the suspension outfits like Fatman and attach to my Plymouth. I also thought of just getting the IFS kit and then getting all the components like A arms, Spindles etc separately as a possible cost saver.
Old 04-11-2007, 12:21 PM
gROCERYgEtteR's Avatar
Ifs
I dont know what your frame looks like exactly, or the width. But I did do it on my "40 plymouth and at one time , 2 years or so I had some pic on here of it. Now the '40 I am pretty sure it differnt because it had IFs stock, and the two big humps in the frame were the spring cups. I did just graft it in, it was a fair amount of work, but it seems to be alright.However i do believe if u have the money http://www.streetrodengineering.com/...ifssubassm.htm
there is someone out there that makes a sub frame for your application, and it looks pretty good this is not it<<<<<<.I will chime back in if I can find it it has been a while since i looked. After doing the graft i would say buy the sub frame, it will cost you money but save you time to work on more exciting, less stressful things.
Old 04-11-2007, 12:54 PM
Ifs
I cant seem to find it, like i said it has been a while but it also appears that there are others that have that sub now where 3 years ago there was one builder.
PM me and Ill get you some pictures
Old 04-11-2007, 07:34 PM
30desoto's Avatar
Dodge ain't all bad
37ply
You might check streetrod engineering they have a kit for your car
http://www.streetrodengineering.com/...gllifskits.htm
30dee
Mustang II IFS Install in 57 Chevy Truck mestes Suspension - Brakes - Steering 7 01-24-2012 09:12 AM
Mustang II IFS Torque specifications Marv37 Suspension - Brakes - Steering 6 07-19-2011 03:50 PM
Later than Mustang II IFS moparist Suspension - Brakes - Steering 9 06-09-2006 08:09 PM
mustang II ifs specs Blob Suspension - Brakes - Steering 1 12-24-2003 10:48 AM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 01:43 PM
