mustang ii ifs conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2012, 01:30 PM
Ihave A 55 Ford Coustomline And Bought Mustang Ii Ifs To Be Installed. The Crossmember,is Universal. The Frame Is To Wide.my Question Is'what Is The Best Way To Narrow The Frame Rails? Has Anyone Accomblished Amustang Ii Ifs On A 55 Ford Car
Old 01-10-2012, 01:56 PM
Last journal entry: Journal Update
Give the guys over at JW RodGarage a look. If I recall they may have the correct crossmember and all the pieces you need without having to narrow your frame.
JW Rod Garage 888-414-8787
Old 01-10-2012, 02:01 PM
Wiki Edits: 31
MII is quite light duty for a '55 Ford.. I'd sell it and get somthing that actually fits, or at least the right crossmember. they make several widths, tho diffrent manufactures are not created equal to others... The original suspension is decent. I would rebuild it, hook a modern steering box to it and mod the OG column to fit it or get a new column and be done with it
Old 01-10-2012, 04:01 PM
BOBCRMAN@aol.com's Avatar
There are plenty of parts available to use the stock stuff. Convert to disc brakes and use an early 80's Cavalier power rack steering. A good sway bar..Works good.
Old 01-10-2012, 04:37 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
mustang II "universal crossmember"s come in different widths
you need to get a wider one
Old 01-10-2012, 04:44 PM
& matts38chev
here is some info http://www.welderseries.com/blog/online-store/ws14540/ scroll down some
Hey i need some help w my Mustang conversion SouthernRascal39 General Rodding Tech 5 05-23-2009 01:26 PM
Mustang I6 To 289 Conversion seahail7 Engine 6 11-15-2006 02:12 PM
Mustang Engine Conversion behotch5 Engine 40 06-03-2005 06:35 PM
Mustang V-6 to V-8 conversion stvnbrs Engine 23 07-12-2003 09:49 PM
