Mustang II IFS with Ford brake calipers - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2011, 10:09 PM
Mutt's37Buick's Avatar
Does anyone know if there is an aftermarket Mustang II IFS that can be bought with Ford brake calipers? Preferably calipers used on late model Crown Victorias.
Old 09-04-2011, 09:06 AM
After further research, I would like to use '99, or newer, Crown Vic or Mustang calipers on the front of my '37 Buick with a Mustang II suspension. Does anyone know if a kit can be bought or assembled like this?
Thanks
Old 09-04-2011, 09:24 AM
Wiki Edits: 27
Calipers
I saw pict's and info on using late mustang cobra calipers on one of the Classic mustang or ford falcon-Fairlane sites. The guy make some simple brackets. Welder Series has the do it your self brackets for Mustang II to use either GM ( General Motors) or Granada Monarch Versailles calipers And they sell iindividual pieces. you could sheck them out.Use some welder series parts and make your own adaptor flat pieces with the right hole locations=stops for the ford pieces. The later design Ford calipers similar to the GM design work a lot better than the old Granada-Monarch calipers which tend to stick and wear out one side of your rotor unless you regulary service-de-rust lube the slides.
Old 09-04-2011, 10:25 PM
Thanks for the leads on where to look. I'll check it out.
Brake calipers that fit s10 drop spindles clarky06 Suspension - Brakes - Steering 1 01-29-2011 11:28 AM
gm brake calipers? 49fordp/u Suspension - Brakes - Steering 14 06-18-2008 07:51 PM
'68 GTX Front Disc Brake Calipers??? Big Mouse Suspension - Brakes - Steering 5 06-06-2008 08:52 AM
Wanting to use GM rotors and calipers on Mustang II spindles IRELAND EXHAUST Suspension - Brakes - Steering 1 04-19-2007 07:07 PM
66 T-bird Brake calipers replacement ethel01 Suspension - Brakes - Steering 23 10-26-2006 04:25 PM
