Mustang II IFS Install in 57 Chevy Truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2004, 12:11 AM
mestes's Avatar
Talking Mustang II IFS Install in 57 Chevy Truck
I am looking for some information/documentation/pictures on installing the Mustang II IFS in my 57' Chebby Truck. Looking at the boxing plates, cross member set up, I will have to notch out the bottom of the frame a bit for the installation of the boxing plates. Before I measure twice, cut once, I would like to hear from others on this issue. The IFS is from Hartrods.com. Appreciate the feed back.
Mike
Old 07-09-2004, 11:57 AM
New Member
Last journal entry: 1952 5-window Chevy p/u
This is an easy thing, I did it on my '56 Chevy p/u. Your right about the measuring part, do it 20x's! One very important thing is to find your old axle centerline, then find the middle of your crossmember (lengthwise) and line the two up. Tack weld!!!!! and remeasure again front to back, side to side and criss cross. Are you welding it? I have a Lincoln mig 110v that worked great on this project, great investment. Are you bending the strut rods or using tubular upper/lower control arms. I used the strut rods, no problems. I also strongly recommend using a power steering pump, custom make your high pressure hose (braided) and use the newer power rack out of the 79-91 Mustangs (not totally sure on those years). You'll have to get a rack extension for that rack model, see www.fatmanfabs.com for more info on that. You can get a steering pump out of any chevy impala or truck out of the junkyard, check the fluid to see if it' clean and you'll be in good shape, also grab a mount for it too while you're there. I did not like the manual rack for this big of a truck, power steering is soooo much better.
Charlie
Old 07-09-2004, 09:07 PM
mestes's Avatar
Thanks for the reply Charlie. Yes I am welding with a mig. Plan is just that, tack weld, measure 20X, then weld. The IFS kit comes with the measurements for the 55-59 Chevy. 20 7/8" from the front spring mount hole. This is exactly where I marked the center of the old axle prior to removal. No strut rods on this one, using the upper and lower control arms, but I do have the manual rack. Have been thinking about the power rack. I do have a power steering pump out of an 85 Camaro that can be used. I have instrcutions from Hartrods.com and illustration is good. Never hurts for second, third and fourth opinions. Thanks for the tid bit of helpful information.
Mike
Old 07-10-2004, 09:49 AM
New Member
Cool
You're welcome. If your wife and/or girlfriend will drive this thing you'll want that power rack, I'm telling 'ya!
Old 07-10-2004, 09:55 AM
willys36@aol.com's Avatar
Wiki Edits: 21
You need to do a LOT of reading B4 picking up a torch!
Read all fo this.
Old 07-11-2004, 02:13 PM
adtkart@aol.com
Like Willys said, do alot of reading before going too far. There has been alot of discussions on these types of swaps. Alot of safety info out there.
Old 01-23-2012, 09:43 PM
Heidts IFS
I am the owner of a 1959 Chevy 3200 Truck. I would like to know if any of you believe the Heidts IFS Mustang II Clip is a better quality IFS to go with or is a TCI IFS a better product? Thanks for the input.
Old 01-24-2012, 08:12 AM
Wiki Edits: 21
They are both probably OK IF you do not use the strut rod eliminator lower A-frame. If you decide to eliminate the strut rods, the X-member will crack and fail, only question is when.
The factroy designs ALWAYS include the equivalent of a strut rod (wide spacing) on the lower A-arms. The following selected photos all show WIDE lower A-arms. The stress must be spread like this or there will be fatigue failure.
Dodge Dakota
1950 Plymouth
