Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mustang II IFS Torque specifications
Old 01-09-2007, 05:09 PM
badA31 badA31 is offline
Marv, I installed a factory M/II front under my A coupe years back. I still have the pages I copied from an old shop manual back then. There are some torque specs in it but they may not all apply to your setup. I'll give you what's here.
Lower arm to crossmember- 95-110
upper arm to frame- 95-110
stabilizer bar to lower arm-15-18
ball joint to spindle(upper&lower) 75-90 (tighten to minimum and then tighten to nearest cotter pin slot)
strut to lower arm 40-60
stabilizer bar to frame 6-12
shock upper attachment 22-30
shock to lower arm 70-80
brake backing plate and cylinder assy. to spindle 20-35
strut to frame 70-80
support yoke cover to housing 15-20
pinion cover to gear housing 15-20
steering gear to crossmember 80-100
connecting rod end to spindle arm 35-47(torque to 35 and go to nearest hole)
I hope you'll find what you need in that list!
