Mustang II ignition switch wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2008, 11:18 AM
I am using the running gear from a 1977 MustangII in a 1941 Ford street rod, including the steering coulum. The engine is a 302 efi from a 1990 Crown Victoria with an aftermarket wiring harness. The harness requires a connection to the ignition switch that is hot during run and start. Is the red/litblue wire from the switch to the coil hot during start? Logic tells me it should be but mine isn't, nor are any of the other wires from the switch. Any information you could provide would be greatly appreciated.
Thanks
John Hawes
Old 12-09-2008, 01:18 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Moving to electrical..I generally try to get a chiltons manual for the donor car to help me sort out the wiring...
Sam
95 Camaro fan switch problem / ignition key problem human_forklift Electrical 12 05-29-2015 07:57 PM
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Mustang II front shocks not "tall" enough BobbyG-39 Suspension - Brakes - Steering 8 08-10-2004 05:36 AM
Mustang II bump steer, drifting Chev283 Suspension - Brakes - Steering 2 06-19-2004 08:15 PM
