Mustang II Kit Failure - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 07-16-2003, 09:44 AM
bigbird's Avatar
Last journal entry: Blasting Cabinet
Smile
Thanks....great idea.
Any thoughts on torque? Since I haven't started this assembly yet, I'm not even sure if a torque setting is recommended anywhere.
  #47 (permalink)
Old 07-16-2003, 09:50 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Hee is a generic chart of torque specs for various bolt grades and sizes. Should be fine for this application.
http://www.spanishtrailrovers.com/Te...olt_torque.pdf
Does the bottom through-bolt rotate in the tube or is it to be cranked down tight and serve only as stub shafts? I am not familiar with the X-member.
  #48 (permalink)
Old 07-16-2003, 02:45 PM
bigbird's Avatar
Got to plead ignorance on that one since I haven't even spread out the parts yet.... just got them late last week...but when I read this thread I got VERY concerned and had to ask some questions.
Thanks for the torque info.
Fred
  #49 (permalink)
Old 10-13-2003, 06:38 PM
pshooter's Avatar
Good point about the torsional failure. If the bolt needed to rotate and was frozen, grade "48" wouldn't help. mvm
  #50 (permalink)
Old 10-13-2003, 08:52 PM
The bolt does not rotate
  #51 (permalink)
Old 10-13-2003, 08:59 PM
tgcustoms's Avatar
New Member
Bolt
At no poit should this bolt ever serve as a pivot point it just holds the control arm in place thats why there are serrations in the bushing sleeves they dig into the metal and keep the rotation in the rubber where it should be...
  #52 (permalink)
Old 10-16-2003, 03:12 PM
Darkman270's Avatar
Larger bolt installation?????????
First let me say that I have learned a lot this afternoon reading this post. No more grade 5 for me. I too was lead down the fairy tale that grade 5 had a higher shear load than grade 8. Thank you for enlightening me.
My question I am planning on using the factory Ford lower control arm and would like to use the 5/8" bolt but does Fatman have bushing for the factory piece that has a larger id bushing? I am planning on using the factory strut rod.
  #53 (permalink)
Old 10-16-2003, 07:42 PM
Darkman, if you are using the factory lower control arm and strut rod, then you are very safe with the factory bolt. The strut rod is designed to absorb the bulk of the shear load. Those of us running tubular lower control arms and no strut rods need to be very concerned about shear loads.
Trees
  #54 (permalink)
Old 10-17-2003, 05:34 PM
Darkman270's Avatar
That is what I'm figuring too but I'm getting a little paranoid and figured a bigger bolt would be better if it fit. LOL
  #55 (permalink)
Old 10-19-2003, 05:16 PM
My experience with Fatman.
I bought a Gibbons torsion bar kit that was junk. I could not get a good ride. I was at the f100 nationals in pigeon forge and mentioned it to Fatman. He was demo ing his front ends. Low and behold, in about an hour he came out to my truck and .....
for an hour and half he laid under my truck personally trying to help me with a gibbons front end . I had never talked or met the man before then. I offered to pay him and he would not take any money.......
Would you like to know what my opinion of him is???????
Jimmy in nc
P.S. Gibbons showed up the next year at the f100 nationals with their f100 56 truck. It had a VOLARE FRONT END UNDER IT.
NO Joke.
  #56 (permalink)
Old 10-20-2003, 01:45 PM
PrimeMover's Avatar
Sittin' on top of the world...
Well I'm a little late chiming in here, with my two-bits worth. Lots of interesting "opinions" and experiences here. I've got a Heidt's A-arm set up in the 53, so I figured I'd just lay back and see if anyone came up with any other possible reasons, other then the age-old "flawed design idea" or sub-standard or wrong grade of bolts being used.
I don't know about Fatman's kits but I DO know a little about Heidt's. If the strut eliminator "kit" Fatman offers is similar to Heidt's here's what I think might have happened..
First off, Heidt provides grade five bolts gussets and tubular extensions that you have to weld in yourself. The instructions state that to achieve proper kit bolt hole alignment, a stack of washers needs to be used in conjunction with the lower a frame bolt so it can be used to bolt and hold everything in place while it is welded. I'm no metallurgist either but I figure, once enough heat has been applied to this assembly to marry everything up properly, you might as well scrap the lower control arm bolt - it's been heated stretched and relieved. Especially if the threaded end of the bolt was temporarily installed where all the heat was being generated.
I went with new lower A-frame bolts for this reason alone - it's cheap insurance.
  #57 (permalink)
Old 10-20-2003, 02:15 PM
Wiki Edits: 21
Prime, you are absolutely correct that the strenght of that bolt is compromised if it reaches 'straw' colored temperature. NEVER reuse bolts that have been used in welding mock-up.
You guys aren't giving me a very good impression of the aftermarket X-member vendors with all these horror stories you are telling! I'll stick w/ my stock Ford MII units. Maybe not quite as pretty but at least they have a better than average chance of staying und the car for a few years!
  #58 (permalink)
Old 10-20-2003, 04:50 PM
PrimeMover's Avatar
Re: Bolt
Originally posted by tgcustoms
At no point should this bolt ever serve as a pivot point it just holds the control arm in place thats why there are serrations in the bushing sleeves they dig into the metal and keep the rotation in the rubber where it should be...
What he said! This is why, the inner lower A-arm through-bolt and the upper A -arm bushing retainer bolts should be left loose until the car rests at normal ride hight under the full weight of the car. If tightened with the suspension hanging in the air, both the upper and lower bushings will last probably a year at best. This is not limited to MII suspension, this is true with most any rubber-bushed front end.
PrimeMover
  #59 (permalink)
Old 10-21-2003, 08:22 AM
Maverick's Avatar
I have noticed here lately that the companies that make and sell the MII kits (Heit's, Fat man, Ect) aren't advertising them as much in the various rags. Instead they are pushing their sub-frame kits. Makes you wonder!
  #60 (permalink)
Old 10-21-2003, 08:44 AM
Wiki Edits: 21
