Mustang II MBM 2" Drop Spindles - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2010, 07:09 PM
Butch60's Avatar
Last wiki edit: Sourcing grilles Last photo:
I have a set of MBM Mustang II 2" drop spindles attached to screw in type tubular A arms top and bottom. The problem I'm having is with the ball joint's dust boots. The bottom dust boot is completely collapsed and the top is not quite as bad. I also noticed that washers are used under the locking nut as spacers. Could I have the wrong ball joints for these spindles, if anyone have experience anything similar I would appreciate any help.
Old 12-25-2010, 08:30 AM
BOBCRMAN@aol.com's Avatar
Either the wrong ball joints or the taper in the spindles is cut too deep. I would go for wrong ball joints. As ball joints are available with several different size tapered studs.
Old 12-25-2010, 01:29 PM
The screw in ball joints are Chrysler and they are longer above the taper than a MII spindle. All of them I installed need the washer to take up the space between the nut and spindle.
drop spindles caletcb Hotrodding Basics 3 12-09-2009 04:02 PM
F-100 drop spindles BAD JONNY Suspension - Brakes - Steering 2 03-04-2005 09:34 PM
2" Drop spindles Bob (Zody) Suspension - Brakes - Steering 2 02-08-2005 04:59 PM
drop spindles bobrefill Suspension - Brakes - Steering 1 10-31-2004 05:46 AM
Should I use drop spindles? 57Chevyman Suspension - Brakes - Steering 6 12-12-2001 10:38 AM
