Mustang II p/s rack - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2011, 06:36 PM
Last journal entry: Volkswagen V8 Squareback project.
Mustang II p/s rack
I have a question regarding the lines on a Mustang II power steering rack. On the metal lines, can rubber lines be used instead of the steel lines? Is there too much pressure for rubber lines? The reason I ask is, with my project, I am cramped for space using the metal lines.
Old 11-08-2011, 12:33 AM
35terraplane's Avatar
Mustang II
I wouldn't use rubber just because of the pressure, when you build these things, where there's a will there's a way.
Bob
Old 11-08-2011, 05:33 AM
SSedan64's Avatar
You can use Braided Hose with Teflon lining. Similar to what's used for Hydro Boost Brake etc...setups or have some Hoses made at a Hydraulics Supply House which may be cheaper.
Example for Power Rack >> http://www.ebay.com/itm/1-Piece-Ford...item3f0c7b57a4
mustang II rack Lil John Suspension - Brakes - Steering 2 04-30-2008 08:35 PM
Mustang 2 rack new vs. used Dave 39 Suspension - Brakes - Steering 2 01-07-2008 08:20 PM
Mustang rack & pinion John Ragazzo Suspension - Brakes - Steering 1 04-28-2007 06:34 PM
mustang ll rack willysbeast Suspension - Brakes - Steering 2 05-01-2006 05:23 PM
mustang II steering rack 35chev/302gmc Suspension - Brakes - Steering 1 07-08-2005 06:24 PM
