Mustang II power rack/GM pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2009, 12:02 PM
57halfton's Avatar
Has there been any new developments lately to make the GM power steering pump more compatible with the Mustang power rack and pinion steering?
I have this setup in my 57 Chevy pickup along with a Mustang II front suspension. I installed a Heidt's adjustable valve in the fluid lines years ago and it works ok but I was wondering if anyone has developed newer technology lately ?
Thanks , Gene
Old 03-15-2009, 06:30 PM
I have a power MS II rack in my '67 Nova (Heidt's front end), and I bought the Heidt's adjustable valve, also. But, looking further, I found that Borgeson's makes a Chevy Saginaw pump with the pressure valve modified for the MS II power rack, so I bought one.
http://www.borgeson.com/POWER%20STEERING/PUMPS.html
I have yet to get the car running, so don't know how it works.
dc
Old 03-16-2009, 05:11 PM
57halfton's Avatar
DC How close are you to getting your Nova running? Waiting to see how you like that power steering pump. Yeah, that Heidt's valve thing didn't quite cut it, I just kind'a found a spot in the middle and got used to it but it's still to sensitive.
Gene
Old 03-17-2009, 01:53 AM
techinspector1's Avatar
Wiki Edits: 326
What's wrong with doing it properly and making brackets to run the MII pump on the Chevy motor? That's the way I do it when I do an engine swap of any kind. Every time I read of someone having problems with an MII rack and Chevy pump I just shake my head and move on. Don't know why I responded to this thread.
Old 03-17-2009, 09:15 AM
Gene
I'm still pretty far out on getting it running. Only thing I need is time and money to get it going...
Old 03-17-2009, 09:22 AM
Originally Posted by techinspector1
What's wrong with doing it properly and making brackets to run the MII pump on the Chevy motor? That's the way I do it when I do an engine swap of any kind. ...
I don't know why others don't make their own, but for me, I don't have the skills and equipment to make a single bracket. And, I don't like the looks of the Ford pumps.
Why not build/offer to build Ford pump brackets for those who don't want to take the time make them ourselves? Seems it might be a market for them.
Old 03-17-2009, 05:03 PM
57halfton's Avatar
Hey Techinspector
Yeah know , I've thinking about just that very thing , would you please share some of your knowledge and wisdom with me and other fellow rodders and maybe point us in the right direction so we can also do a Mustang pump instead of a GM pump. The proper parts to get and maybe some photos would be terrific. You could even do a Tech Article Wiki.
Anyway , seriously I have though about doing that , got any tips and pics ?
Gene
Old 05-22-2017, 01:56 PM
If you're using a GM Saginaw pump with a MII Rack, Just get a 6174B pump from Summit Racing. It's already set up for the lower 850 PSi and 2 GPM required for MII. No messing around with shims, flow restrictors or adapters. Works great right out of the box.
Old 05-23-2017, 10:31 AM
ogre's Avatar
the 'Duracell Project'
hopefully the op has figured it out in the 8 years since he posted this
Old 05-23-2017, 01:15 PM
This is a common headache with M II rack mated to a GM PS pump. I was posting for others to keep this in mind on their builds. Not only that but 8 years ago you had to mess with shims, adapters, regulators, and other nonsense. Now you can buy parts and hook them up and go. Info is valuable.
Old 05-23-2017, 01:27 PM
454 Rattler's Avatar
NEVER SATISFIED !!
I don't think it ever hurts to bring up an important subject. Some guys are still looking for the correct answer.
454 RATTLER
Old 05-24-2017, 11:09 AM
ogre's Avatar
in that case make brackets to mount the ford pump to the sbc
i run a gm pump with the flow reducer with the thunderbird rack it still doesn't feel right
if i had it to do over i'd run the ford pump
Mustang II Power Steering Rack Dave42 Suspension - Brakes - Steering 7 02-13-2006 05:26 PM
Mustang II power rack rebuild americanLT1 Suspension - Brakes - Steering 5 04-08-2005 06:47 PM
Power steering/snow plow pump jrm123180 General Rodding Tech 1 08-19-2004 07:59 AM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
