Mustang II power rack rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2004, 12:30 PM
Last journal entry: Body work
Has anyone rebuilt there original mustang II power rack themselves, and is it worth it? Are there upgraded units that are better than the originals that are reasonably priced. I'm not sure what year this rack is. Also, I'm using a 1994 lt1 motor in my 59 rambler American, what sort of compatibility issues will I have with the type of pump used on this motor. Thanks for your help Ed.
Old 04-07-2005, 12:22 PM
willys36@aol.com's Avatar
Wiki Edits: 21
You should find your answer here.
Old 04-08-2005, 08:44 AM
I went too Checker and got anew rebuilt for peanuts you should consider that! Even had warrenty
Old 04-08-2005, 09:49 AM
Wiki Edits: 21
I NEVER buy when there is the slightest chance I can restore a junk yard part myself. I enjoy the process more than the result I guess. And that leave the peanuts for me to eat!!
Old 04-08-2005, 12:17 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Learning factor
There is also the learning factor to consider when you do your own thing..once you have done it now you are the guy that knows..
First time around can be a bit of heartache to get the proper tools and such but then I have found that investment pays off..
OMT
Old 04-08-2005, 06:47 PM
Wiki Edits: 21
OMT
Yep. I can now have a 100% perfect condition MII power rack for junk yard price (+ $15) plus powder coating, polished aluminum or whatever finish I want. Polished OD auto trannys cost me $50 for the core plus a rebuild kit and shift kit & misc repair parts, usually way under $400. That, plus the satisfaction of DIY.
