Mustang II Power Steering Rack
Building a street rod with Mustang II power steering rack and a GM power steering pump. Anyone have any idea what the specs/sizes on the high pressure and return ports on this rack are? My friendly hose fabrication guy says "Bring me the rack" and he'll make the hoses. I'd rather bring him the fittings if I knew what they were. Also, which port is the high pressure, and which is the return? Any assistance is appreciated. Dave 42
Call Van Enblom at Fat Fenderered Street Rod Shop he can fix you up with hoses and all fittings.Just be sure you know what year your rack is.To reach him:
1-888-276-6555 You will be askin for: Powr stering hose kit Port Adapters(convert to inverted flare) Good Luck |
Mustang 2 Power Steering Rack
Hi Dave; I need the answer too. Which is supply and return?
There were two different racks used on the Mustang II. One was a Ford and the other was a TRW I believe. They have different fitting sizes so make sure you know which one you're dealing with.
Ford unit is on the left (bolt on pinion) and the TRW one piece unit is on the right http://www.gottashow.com/art/rack_pinion_views.gif |
Mustang II Power Steering lines
Nice pictures;but if it doesn't show me which is the supply (hi pressure) hole and which is the return hole, it doesn't do me any good. Thanks for trying, but more info. would be nice. Thanks, Stan
So you'll know, the small port is the high pressure side and the larger port is the low pressure return and as I said before the fitting size will vary depending on which unit, Ford or TRW, you're using. |
Centerline;sorry for not folowing protocal,there I go again, I should probably be writing to you somewhere else,but if you'll notice in the new posts I was trying to get the answer on my own; but my post was going nowhere(like my car is until I get the hoses hooked up right). So once again; sorry to Centerline and Dave42 for intruding on his post. Thanks; Stanjr41. P.S.; Thanks Centerline for the answer.
| All times are GMT -6. The time now is 01:33 PM. |
