Originally Posted by stanjr41
Nice pictures;but if it doesn't show me which is the supply (hi pressure) hole and which is the return hole, it doesn't do me any good. Thanks for trying, but more info. would be nice. Thanks, Stan
I wasn't answering YOUR question with that particular post. Generally speaking if you want a specific question answered you should start a separate thread and not tack it on to someone else's question.
So you'll know, the small port is the high pressure side and the larger port is the low pressure return and as I said before the fitting size will vary depending on which unit, Ford or TRW, you're using.
