Mustang II power steering rack question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2008, 04:55 AM
Last journal entry: Bringing home the 401 Nailhead
I originally had a Mustang II manual rack on my 34 chassis. I decided to go with a power steering rack. No problem with the switch until I mocked up the radiator. The hard steel lines need to be rerouted. Any suggestions on making new lines? Don't recognise the flange.
Picture added for clarity:
Old 12-16-2008, 05:14 AM
mustang
I have no answers for you but was wondering if I could get the measurement on the manual rack I need to know how far apart are the pivot points and over all width thanks mike
Old 12-16-2008, 05:37 AM
"new Hard Steel Lines" on the Radiator (trans), or the Rack , or on the PS pump to rack?
Old 12-16-2008, 06:52 AM
302 Z28's Avatar
What kind of pump are you going to run? Just wan't to make sure if it's a GM pump that you know about the over pressure issue using a GM pump with a Mustang II rack.
Vince
Old 12-16-2008, 06:55 AM
Not sure what you mean "pivot points". The bushing centers that bolt the rack on are 16". They do make offset bushings so I guess you could 15 1/2 to 16 1/2. Overall width - do mean tie rod end to tie rod end?
Old 12-16-2008, 07:05 AM
The hard steel lines (similar to brake line) on the rack that connect the steering gear to the actual rack. See picture.
Old 12-16-2008, 07:07 AM
Vince
Thanks for the thought. "Low Flow" pump came with the kit.
Old 12-17-2008, 08:35 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Those hard lines use an o-ring seal on a flange if I remember correctly. I have not come across a tool for re-creating those flares.
In the past I have taken the lines off and rebent them for clearance. Another option is to cut the line in a convenient spot, install a flare or inverted flare fitting and then either use a hose, or new hard line with a union to reroute the line.
Old 12-18-2008, 04:39 AM
Thanks - never thought of cutting and splicing. Might try that as a last resort.
Mine do not have an o-ring. The flare looks double crimped and flat. I spoke to the fellow at Inline Tubes and they could not help with fittings. Said they could not duplicate the flare.
Mustang II power steering johnhawes Suspension - Brakes - Steering 3 09-18-2008 04:07 PM
Bel air power rack question new_rat_rodder Suspension - Brakes - Steering 3 10-06-2007 10:32 PM
My first ever question, adding power steering awert Suspension - Brakes - Steering 1 02-23-2007 12:49 AM
Mustang ii steering rack DAVIDTEDDYBEAR Suspension - Brakes - Steering 2 01-31-2006 06:53 AM
Flaming River Mustang II Power Rack? acr Suspension - Brakes - Steering 1 02-19-2004 05:57 AM
